AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
some columns in database don't show
6 REPLIES 6
245 Views, 6 Replies
I have a mdb connected to a dwg via acad map. When I view my database in
access, it shows many more columns than when I view it it autocad map.
Anybody know how I can edit this data in Map, so I can get the other columns
to display.
MKH
6 REPLIES 6
to continue the above post....
When I go to view>unhide all columns, it is greyed out to where I can't
select it.
MKH
"mkh" wrote in message
news:5317883@discussion.autodesk.com...
to display.
MKH
you can dettach an reattach de dB, sometimes the refresh not work property,
if you change the db structure a minor change ...
Kalmy
news:5317977@discussion.autodesk.com...
select it.
MKH
to display.
MKH
will I still have my links?
MKH
"Albert Kálmán "
<=?UTF-8?Q?Albert_K=C3=A1lm=C3=A1n_?=> wrote in
message news:5318854@discussion.autodesk.com...
Kalmy
select it.
MKH
to display.
MKH
You will not lose your links if you detach the data source.
news:5319084@discussion.autodesk.com...
MKH
"Albert Kálmán "
Kalmy
select it.
MKH
to display.
MKH
Yes!
Kalmy
MKH
"Albert Kálmán "
Kalmy
select it.
MKH
to display.
MKH
thanks everyone...
thats what I was looking for.
MKH
"Albert Kálmán "
message news:5319515@discussion.autodesk.com...
Yes!
Kalmy
MKH
"Albert Kálmán "
Kalmy
select it.
MKH
to display.
MKH
”Boost
