This has been driving me nuts and I finally tracked it down. I was trying to export attributes with a polygon topology using the closed polylines method with a linked database. The output file kept coming out with the right number of records but completely empty. All of the records in the first field of the database were empty, and that was the problem. I relocated the key field, that also had filled records, to the beginning of the file and the export worked OK. Whew.
