Size of labels in model and layout modes,
I couldn’t figure out how the label size is controlled at the layout mode. Please, have a look on the two attached screenshots that shows the label size in model and layout modes
Thank you
Best
Jamal
Solved by Alfred.NESWADBA. Go to Solution.
if you have the dialog open with the label-style you have the choice to define the textsize (the first line in the dialog) based on absolute or relative units (sorry that I don't have the english word for it, but see the screenshot therefor.
If the left side is checked, then the textsize is relative to paper, on the right side the textsize is absolute for modelspace.
HTH, - alfred -
Many thanks Alfred for the help. It works fine (attached).
Best
Jamal
