AutoCAD Map 3D General Discussion
Active Member
jwest
Message 1 of 10 (264 Views)
SHP File
264 Views, 9 Replies
03-07-2012 06:20 AM
When importing a shp file for street names into my map Map 3D see's it as a polygon. When I edit it to text it has 4 street names in the shape of a polygon. Is there any way to convert this shape to show only one street name?
Distinguished Contributor
nwray
Message 2 of 10 (228 Views)
Re: SHP File
03-08-2012 08:10 AM in reply to: jwest
Could you post a portion of the file so I could take a look at it?
Norm
Active Member
jwest
Message 3 of 10 (210 Views)
Re: SHP File
03-09-2012 04:15 AM in reply to: jwest
Here is the shape file i was asking about. Thanks for the help.
Murph
Message 4 of 10 (208 Views)
Re: SHP File
03-09-2012 04:26 AM in reply to: jwest
What coomand are you using to create the text? I used map annonation blocks and only get one label per polygon.
Murph
Supportting the troops daily.
Active Member
jwest
Message 5 of 10 (205 Views)
Re: SHP File
03-09-2012 04:29 AM in reply to: jwest
Im new to map, i just pulled it in as a shape file. Should i do something diffrent?
Murph
Message 6 of 10 (203 Views)
Re: SHP File
03-09-2012 04:36 AM in reply to: jwest
Pulled it in? HOW, what command did you use? Mapimport, drag and drop from windows explorer, dataconnect or what?  How do you know it has 4 streetnames? What are you using for creating the text lables?
Murph
Active Member
jwest
Message 7 of 10 (197 Views)
Re: SHP File
03-09-2012 05:22 AM in reply to: jwest
Dataconnect.
Murph
Message 8 of 10 (193 Views)
Re: SHP File
03-09-2012 05:33 AM in reply to: jwest
I'm only getting one label with dataconnect. (2011 version)
Murph
Nero1960
Message 9 of 10 (190 Views)
Re: SHP File
03-09-2012 05:45 AM in reply to: jwest
Spoiler
Hi JWest...
opened your shapefile in ArcInfo and it is a polygon and there are street names under the field "TextString"
opened Map 3D and brought the shapefile
I connected to the shapefile...then changed the style to show just the text...in the Task pane click on Style
then see if you can change the properties to mimic my attachments...
hope this helps...
GO Texans!!!
Active Member
jwest
Message 10 of 10 (161 Views)
Re: SHP File
03-09-2012 08:03 AM in reply to: jwest
Thanks NERO that worked great.....
