AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
SHP File
9 REPLIES 9
Message 1 of 10
jwest
571 Views, 9 Replies
SHP File
When importing a shp file for street names into my map Map 3D see's it as a polygon. When I edit it to text it has 4 street names in the shape of a polygon. Is there any way to convert this shape to show only one street name?
9 REPLIES 9
Message 2 of 10
nwray
in reply to: jwest
Could you post a portion of the file so I could take a look at it?
Norm
GIS Specialist
BOXX Technologies APEXX 2 2402 Workstation
Intel Core i7-6700K @ 4.4 GHz
32 GB RAM / 500 GB SSD
NVIDIA Quadro M2000 Graphics
Windows 7 Pro 64 bit C3D 2017
Message 3 of 10
jwest
in reply to: jwest
Here is the shape file i was asking about. Thanks for the help.
Message 4 of 10
Murph_Map
in reply to: jwest
What coomand are you using to create the text? I used map annonation blocks and only get one label per polygon.
Murph
Supporting the troops daily.
Message 5 of 10
jwest
in reply to: jwest
Im new to map, i just pulled it in as a shape file. Should i do something diffrent?
Message 6 of 10
Murph_Map
in reply to: jwest
Pulled it in? HOW, what command did you use? Mapimport, drag and drop from windows explorer, dataconnect or what?  How do you know it has 4 streetnames? What are you using for creating the text lables?
Murph
Message 7 of 10
jwest
in reply to: jwest
Dataconnect.
Message 8 of 10
Murph_Map
in reply to: jwest
I'm only getting one label with dataconnect. (2011 version)
Murph
Message 9 of 10
Nero1960
in reply to: jwest
Spoiler
Hi JWest...
opened your shapefile in ArcInfo and it is a polygon and there are street names under the field "TextString"
opened Map 3D and brought the shapefile
I connected to the shapefile...then changed the style to show just the text...in the Task pane click on Style
then see if you can change the properties to mimic my attachments...
hope this helps...
GO Texans!!!
Message 10 of 10
jwest
in reply to: jwest
Thanks NERO that worked great.....
”Boost
