Patrick hi,
I am not sure about VBA or Lisp, but if you made your result "Short Path"
into a permanent topology then you have all it's objects and a simple Map
Query and Report
can give you the answer to what you need. You can calculate sums in Excel,
for example.
Hope this helps,
Arad
"Patrick Robinson"
wrote in message
news:A54BFE168A240BD8EFFA79AA5F040A91@in.WebX.maYIadrTaRb...
> I created a network topology and did a "shortest path" between two points
> and made that its own topology now I want to be able to get the distance
of
> that shortest path (topology) using VBA or lisp. If I go to 'Topology
> Administration' and click the statistics button I can see the total
distance
> but I can't write that value out to anything. HELP!
> -Patrick Robinson
