AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Shift Key Ortho
1 REPLY 1
1321 Views, 1 Reply
Shift Key Ortho
I am having issues with a particular thing I use daily.  When I switched over from AutoCAD 2010 to AutoCAD Map 2014 is when I experienced this issue.
When I hold down the SHIFT key it will toggle ORTHO mode on or off.  It has always done this but the issue is that now when I hold down the SHIFT key it will not actually allow me to draw a line when I left click.  For Example:
ORTHO mode is off
I type command in to draw a polyline.
I hold down the shift key because I want to draw a straight line
It toggles the ORTHO mode on
I then left click to draw the line but it doesnt draw the line.
This has just always been a shortcut for me instead of actually turning the ortho mode on or off.  How can I fix this?
1 REPLY 1
rkmcswain
This is normally defined in the menu as a temporary override, as shown below. I wonder if your menu has been damaged and this is missing?
Have you looked in your CUI to see if this is present and enabled?
”Boost
