AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Shape file only displays partial in plot
4 REPLIES 4
sboon
356 Views, 4 Replies
I have a user who is trying to plot several design drawings which all have a connection to one shape file.  The file in question is used as background data for the design and is apparently fairly large.  When he plots the drawings only part of the shape data comes through.  Based on the information I have it sounds like the software does not have enough time to retreive all of the shape data before the plot data goes to the printer.
Anybody have a suggestion for how to fix this?
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
Expert Elite Alumnus
4 REPLIES 4
antoniovinci
in reply to: sboon
If you plot to a virtual PDF printer, how does it appear in Adobe Reader..?
sboon
in reply to: antoniovinci
It doesn't seem to matter what printer is involved.  All plots appear the same way, with some of the shape data missing.
Steve
phil_borycens
in reply to: sboon
Are actual geometry pieces from the shapefile disappearing during a plot, or are stylized labels from the shapefile disappearing from the plot?
Phil Borycens
sboon
in reply to: phil_borycens
Apparently some of the geometry does not plot.
Steve
”Boost
