Setting the label size for multiple thematic rules,
I couldn’t figure out how the label size can be set for multiple thematic rules in one go (attached).
Thank you
Best
Jamal
afaik you can't modify them in one step after you already created the thematic map,
but when you create the theme you can set the size that is to be used for every single style-item ... look to the screenshot.
- alfred -
