AutoCAD Map 3D General Discussion
Active Contributor
murali.pandey
Message 1 of 2 (455 Views)
setting Projection system on dwt file (Autocad Map 3d)
455 Views, 1 Replies
08-13-2012 04:56 AM
Can I define a projection system in drawing template file(dwt).
If yes then how?
Murali
Board Manager
Daniel.Du
Message 2 of 2 (408 Views)
Re: setting Projection system on dwt file (Autocad Map 3d)
08-19-2012 07:34 PM in reply to: murali.pandey
I did a quick try in Map 3D 2013. You can assign a coordinate system from "Map Setup" -> "Assign" button in "Coordinate System" tab, and save it as DWT file.
Daniel Du
Developer Technical Services
Autodesk Developer Network
