AutoCAD Map 3D General Discussion
Active Contributor
0 Kudos
Post 1 of 2
setting Projection system on dwt file (Autocad Map 3d)
557 Views, 1 Replies
08-13-2012 04:56 AM
Can I define a projection system in drawing template file(dwt).
If yes then how?
Murali
ADN Support Specialist
17 Kudos
Post 2 of 2
Re: setting Projection system on dwt file (Autocad Map 3d)
08-19-2012 07:34 PM in reply to: murali.pandey
I did a quick try in Map 3D 2013. You can assign a coordinate system from "Map Setup" -> "Assign" button in "Coordinate System" tab, and save it as DWT file.
Daniel Du
Developer Technical Services
Autodesk Developer Network
