Question: Where can I find a list of the Autodesk Knowledge Network support solutions that were created and/or updated in the month of September?
Week One:
“No Industry Models to update”
AutoCAD Map 3D 2015 now supports Microsoft SQL Server 2012 Standard Edition
Autodesk 2015 product displays a 0.0.0 error
Can AutoCAD be run without a user?
Fatal Error When Launching AutoCAD
Ghost lines and artefact issue appears when zooming in/out with Nvidia GeForce 650M on AutoCAD 2015
How to change the paper background of a layout in AutoCAD
How to use a different color book
The “Copy Block Definition and Assign” command is missing in AutoCAD
Unwanted lines show up on plotted output from AutoCAD
Week Two:
Are there any known AutoCAD compatibility issues with Office 365
AutoCAD Map 3D Industry Model: Crash with creating new Job and selecting Job perimeter from Topology
Block command does not convert selected objects to block definition
Change space does not work on annotative objects in AutoCAD
Default DWF display is zoomed into sheet corner in Design Review
Error: “Unknown command” with all commands after loading custom cui or cuix file in AutoCAD
How to disable view transitions when clicking on the ViewCube in AutoCAD
How to reset AutoCAD to defaults
Keyboard function keys do not work in AutoCAD
Login with Mapsys User to Industry Model: Version conflict found during log-in
Merge AutoCAD Layers
Odd graphics display when working with a high resolution/high dpi monitor in AutoCAD
Orbit hangs for several minutes in AutoCAD with an NVIDIA graphics card
Plot preview is in grey scale
SNAPGRIDLEGACY system variable does not work
Tolerance dialog box displays letters instead of symbols in AutoCAD
Valid Licensing Combinations for Autodesk Vehicle Tracking
When working with Autodesk Vault Thin Client the button for Autodesk Design Review is not active
Week Three:
Commands not working in a viewport in AutoCAD
Error: “Unable to perform the requested action. This drawing was last edited with model documentatio...
Error: Sectioning plane does not intersect the selected solid in AutoCAD 2015
How to change text size on the ribbon and toolbars in AutoCAD
Large PDF file sizes when creating PDFs from the Industry Model Form Designer
Offline help fails to launch after installation
Points appear when inserting drawing as block in another drawing in AutoCAD
Unwanted linework appears when opening drawings in AutoCAD 2015
When opening AutoCAD, we get multiple errors related to acecore.dll.
Zooming and panning in a layout with an activated locked viewport gets stuck in paper space
Week Four:
2012 suite install fails
After the update of the Autodesk Application Manager, the program crashes when trying to update soft...
AutoCAD Map 3D 2015 - Unlock MDSYS in Industry Model using Oracle 12c
Bad definition of FENCELINE1 at line XXX when loading a linetype
CAD Standards Plugins missing
Excel crashes after installing AutoCAD 2015
How to use reality data / point clouds in AutoCAD 2015
Internal Error: !saveres.cpp@154: eFilerError in AutoCAD
PLOT or PUBLISH of drawings containing raster images is slow or crashes AutoCAD
Polylines are thickened by PEDIT > Width command, but displayed as hollow lines
