After a particularly bad crash today, I am having trouble with my selections in Map. All of a sudden, a 'select -all' is checking out geospatial features. Up to this point, I could use a 'select -all' without ever touching the features attached via the Display Manager. I know some settings got hosed because I had to reset the FILEDIA to 1 after the crash.
Anyone know a system setting that may affect how attached features are selected?
Carl
Solved by Alfred.NESWADBA. Go to Solution.
check out this dialog: command _MAPFEATUREEDITOPTIONS, there are some options for automatically check-out and check-in.
Try also command _MAPAUTOCHECKOUT
Hope this is what you searched for.
- alfred -
That seems to have solved the problem -Thanks for the help
