Already tried Find. Some of my block attributes are "invisible". Find won't zoom to invisible attributes or attributes/text on off/frozen layers.
Say there are 14 blocks named "AA" with invisible attribute "M" containing the value "xyxy". With Map 6, I'd quick select on all blocks AA, then narrow it down to look for attribute M = xyxy (or M wildcard match *xyx*). On OK, all 14 blocks would be SELECTed at once, allowing me to immediately do something with those 14 items (change color, layer, size, wblock etc). Find doesn't "select" anything, just zooms to the location of its current "found" item. I'd have to activate Find 14 times, to find all 14 instances of "xyxy", and that assumes that "xyxy" isn't in some other text item or attribute other than "M". Easier to open a new drawing and do a Query.
Any idea why Autodesk got rid of the quick select's ability to see block attributes and object data fields in the currently open drawing?
