AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
SDF2SHP PROBLEM
1 REPLY 1
alexkonieczka
333 Views, 1 Reply
SDF2SHP PROBLEM
FROM C3D I WROTE OUT AN SDF AND IMPORTED IT INTO MAP THROUH FDO CONNECT TO SDF.
I THEN MADE A CONNECT TO A FOLDER TO CONTAIN THE SHP FILES.
FROM MAP TOOLBAR I EXPORTED THE SDF SCHEMA AND IMPORTED IT INTO THE SHP SCHEMA.
THEN WHEN I TRIED TO DO A BULK COPY I GET THIS ERROR MESSAGE:
THANKS, ALEX
1 REPLY 1
I have not had this problem, but I would try:
a) check the coordsystem set in your drawing as the PRJ-file is to store the coordinate-system-settings
b) try to save into a folder that is not in my user-directory (and so not free of any security-permission-settings)
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
”Boost
