AutoCAD Map 3D General Discussion
Distinguished Contributor
Gary_Braun
Message 11 of 14 (507 Views)
Re: SDE Enterprise Connection - No ArcGIS License Found
10-03-2012 01:21 PM in reply to: phil_borycens
Hi Phil,
I'm so glad to see this is "solved", kind of adds new meaning to the word.
In any case, we've just gone through a process of pretty extensive upgrades of our gis servers and other bits of associated software, and I don't think there is any going back to 10.0 at this point. All along the way, I just KNEW this was going to happen.
Thanks for your input Phil, I do appreciate your help.
malcolml
Message 12 of 14 (497 Views)
10-04-2012 07:02 AM in reply to: Gary_Braun
I have just been informed by our GIS group that they are upgrading to Arcgis 10.1. We are currently using Civil 3D 2012 but can move to Civil 3D 2013 if the connection issue has been resolved.
Gary_Braun
Message 13 of 14 (336 Views)
05-30-2013 12:49 PM in reply to: phil_borycens
Okay, so that was then and this is now.
ArcGIS 10.1 has been available since at least August 2013 but Map 3D 2014 is still not able to connect! Nine months now and a new software version, but still no resolution. I find it curious that a relatively small, (though admittedly bright), company like Safe Software has been able to read/write to ArcGIS 10.1 sde and file geodatabases with FME since the day esri 10.1 was launched, but a behemoth like Autodesk seems uanble to pull it off. It really does sound more like a lack of will than anything else.
Has ANYBODY been able to connect to ArcGIS 10.1 data through the ArcGIS FDO connector yet?
anybody?
Gary_Braun
Message 14 of 14 (305 Views)
08-02-2013 10:27 AM in reply to: Gary_Braun
Just to post a solution to my own problem, I have finally managed to make this work connecting 32-bit Map 3D 2014 to an ArcGIS 10.1 SDE data store on 64-bit SQL Server 2008 using the ArcSDE FDO connection.
What I had to do was:
Add an environment variable so Map could pull an esri license.
ESRI_LICENSE_FILE = port@server
Then I had to find the following libraries in my Arcgis desktop BIN folder and copy them into my Map 3D BIN/FDO folder; gsrvmssql101.dll, icudt44.dll, icuuc44.dll, sdemssqlsrvr101.dll, xerces-c_3.1.dll
I don't believe this has anything to do with pe.dll, sg.dll, and sde.dll, I had already added them to my BIN folder and didn't bother to remove them so they are still in there, but the connection did not work until I added the other libraries I've mentioned.
