AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Save and restore PROFILES
2 REPLIES 2
253 Views, 2 Replies
I use MAP6 (2002) and MAP2004 in XP Pro,
and run several 3rd party design packages, which require different profiles, and I would like to set Desktop icons to start up in the different profiles. Following the instructions in the online Acad User Guide, and put /p PROFILENAME after the target, my system comes up with an error message when I select apply, and tells me that the target name is invalid. My IT/CAD support guru says that there is a specific way to enter this. Any ideas ??
2 REPLIES 2
Have you tried /p "C:\Full Path\Profilename.arg" ?
Chip Harper
Member of the AutoDesk Discussion Forum Moderator Program
mgalicki
Would someone post their "target line for me to see.
here are mine:
"C:\Program Files\Autodesk\AutoCAD 2015\acad.exe" /ld "C:\Program Files\Autodesk\AutoCAD 2015\AecBase.dbx"/nologo /p "AutoCAD MEP MG's 2015"
"C:\Program Files\Autodesk\AutoCAD 2015\acad.exe" /p "AutoCAD MEP MG's 2015.ARG"
But they give me a message, "profile not found" & it loads the Vanilla profile, & then I have to load mine.
Everything in existence was first an Idea
Autodesk Plant 3D Premium 2019
Autodesk MEP 2019
HP 3.2 Ghz CPU 16 ram
1TB 7200 rpm SATA 6Gb/s hard drive
2GB DDR3 NVIDIA GeForce GTX 680ti
HP 2311x 23" LED Monitor
”Boost
