I have tried to connect to a SQL Server Spatial database and matched the projection of the incoming data (LL84, both have an EPSG code of 4326).
However, once it is in Civil the data is rotated 90 degrees (see attachment).
I have checked in the 'GEOGRAPHICLOCATION' dialogue box and it shows north as straight up.
Anyone have any thoughts on why this is happening and how to correct it?
there is no attachment in your message, can you retry to upload it?
BTW; you know that the data is correct imported in SQL-Server? Have you any other viewer to verify that?
- alfred -
I attempted to attach it before but it did not upload for some reason. i will try again. I also noticed that it is rotated as well as mirror imaged.
