I've recently started using Map 2011 and am not happy with the new ribbon. Most of the commands that I use for setting up my maps seem to have been removed from the ribbon. Is there a way so that the ribbon set up from Map 2010 can be used in 2011? I just got used to the layout in 2010 and then everything changes.
Michael
I noticed very little change in the ribons from 2010 to 2011. What workspace are you using?
In 20101 I use the tool based, I tried the different workspace options in 2011 and I couldn't find the same layout. I am using 3D Basics.
Just wanted to say that 2012 is a huge improvement over 2011 and has all my favorite tools back on the ribbon.
