AutoCAD Map 3D General Discussion
Active Member
APRR_SITE_DIJON
Message 1 of 7 (446 Views)
Reprojection of multiple DWG
446 Views, 6 Replies
03-05-2014 12:54 AM
Hello guys,
I have a lot of dwg files (more than 100) that I need to reproject from IGN-II-Grid to RGF93.CC46
I know there is a way to reproject One DWG at a time (create new file > set coordinate system, meters unit and source CoordSys > Query with all > save)
This
This method works well but this is tedious work for more than 100 dwg.
So, my question is : Do you have a routine or a batch script that I can use to reproject multiple Dwg (same source CoordSys, same target CoordSys) ?
I know there is "AC Batch Reprojection Utility" that has been developped by Autodesk Consulting but they are unable to provide me this script....
Hope somebody can help :smileyhappy:
Regards
Matthieu
Hello Matthieu
Unfortunately AutoCAD MAP 20xx can reproject N DWGs to ONE DWG ONLY !
or you will have to reproject ONE BY ONE which is very time consumming ...
The French IGN has developped since a few years a Free Tool (IGNMAP) able to reproject N files (Automatic Batch mode) in DXF or SHP or MIF-MID or GC or xxx Format
which are in ONE folder - for example : "C:\DXFINPUT"
to an OTHER folder - for example : "C:\DXFOUTPUT"
This Reprojection Free Tool is able to use the "good old" Lambert 1/2/3/4/ET and of course ALL the New Lambert RGF93 : L93 France Entiere (whole country)  and the NINE L93 CCxx
A lot of people are using in France this Free Tool ...
For example ALL people with an AutoCAD LT or with an "classic" AutoCAD ...
Please try this Free Tool ! And let us konw if you are satisfied !?
Bonjour,
Open a DWG
Specify CC46 to this drawing
Attach your X dwg to the source drawing and specify the IGN.II for these base drawing
Load this lisp and execute RPV at command line
(defun C:RPV ()
;récupère la liste des chemins et des noms des dessins puis détache
(foreach dwg_id (ade_dslist)
(setq ListDwgName (append ListDwgName (list (ade_dwgactualpath dwg_id))))
(ade_dsdetach dwg_id)
;définit la requette Emplacement tout en mode dessiner
;(ade_qrydefine (list "" "" "" "Location" ("All") ""))
(ade_qrydefine '("" "" "" "Location" ("All") "" ) )
(ade_qrysettype "draw")
;boucle d'attachement des dessins 1 par 1
(foreach dwg_name ListDwgName
(ade_dsattach dwg_name)
;exécute la requète
(ade_qryexecute)
;détache le dessinn
(foreach dwg_id (ade_dslist) (ade_dsdetach dwg_id))
;crée le nom du dessin de sortie
(setq dwg_name_export (strcat (substr dwg_name 1 (- (strlen dwg_name) 4)) "_BIS.DWG"))
;zoom étendu
(command "zoom" "et")
;exporte les objets extraits vers le nouveau dessin
(command "sauvegrd" dwg_name_export)
;supprime tous les objets du dessin
(command "effacer" "tout" "")
This lisp find all attached DWG, load first, execute query "Emplacement Tout", save as DWG with same name with sufix _BIS, erase all entities and proceed to next drawing
Sorry for non french people, but command are french instead of international. I could change if necessary
Olivier
antoniovinci
Message 2 of 7 (436 Views)
Re: Reprojection of multiple DWG
03-05-2014 01:41 AM in reply to: APRR_SITE_DIJON
Bonjour, monsieur.
In an empty drawing, set the CRS as IGN-II-Grid, then do a simple script like this:
_-INSERT drawing1. dwg ...
_-INSERT drawing2. dwg ...
_-INSERT drawing100. dwg ...
then save all as "IGN-II-Grid.dwg".
Afterwards, in an empty drawing, set the CRS as RGF93.CC46, attach the above "IGN-II-Grid.dwg", finally perform the draw query.
Maybe it's not what you're after (i.e. 100 single drawings in RGF93.CC46 system), but better than manually reprojecting all, isn't it..?
Active Member
APRR_SITE_DIJON
Message 3 of 7 (434 Views)
03-05-2014 01:46 AM in reply to: antoniovinci
Thanks for your Reply Antonio,
Unfortunatly, I am looking for a way to get single drawings as an output.
Your solution cannot work because it would be tedious too to also cut back 100 dwg files from a large single RGF93.CC46 drawing.
Regards
braudpat
Message 4 of 7 (402 Views)
03-05-2014 10:09 AM in reply to: APRR_SITE_DIJON
Hello Matthieu
Bye, Pat ( Supporting Troops )
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Compliment) - Thanks
olivier.eckmann
Message 5 of 7 (390 Views)
03-05-2014 11:51 AM in reply to: braudpat
Bonjour,
Open a DWG
(defun C:RPV ()
    ;exécute la requète
    (ade_qryexecute)
    ;détache le dessinn
    ;zoom étendu
Olivier
braudpat
Message 6 of 7 (386 Views)
03-05-2014 12:07 PM in reply to: olivier.eckmann
Hello Olivier
BEAUTIFUL !
Active Member
APRR_SITE_DIJON
Message 7 of 7 (371 Views)
03-06-2014 12:21 AM in reply to: APRR_SITE_DIJON
Thanx Olivier and Patrice.
Both solutions are working and can be applied in a fast and efficient way !
Best regards.
