Map3D does not have any thing like the Reports manager in Civil3D. You would
need to query the data export the table to csv format and create reports in
some other application.
If you need to create dwg objects from the features you can always use the
map import command.
Murph
http://map3d.wordpress.com/
"Ahmed.Giwa" wrote in message news:6321288@discussion.autodesk.com...
1. The report is on job processes on Map, similar to the one in Civil 3D
2. I need to extract geometry from the whole feature, is there any other
option from MapFeatureEditOptions?
3. Saving the joined layer to SDF did not work either.
Looking forward to hearing from you thank you.
