AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Rename Multiple Layout Tabs
2 REPLIES 2
richarddauer2297
4777 Views, 2 Replies
I am currently workin on a large drawing that has many tabs (145),  I have made a mistate midway and would like to find a way I can rename them quicker than "Right Clicking" on each tab to change it. That will be very time consuming.  Does anyone have any solution to this.
Also, is there a way to print a list of all of the current layouts within a drawing/
Thanks in advance for any help.
Richard
2 REPLIES 2
knj777
in reply to: richarddauer2297
Have you heard of a lisp routine called "Tabsort"? If you google it, I'm sure you could find it. I think it will work great for what you are looking for.
If you were to consider third party software, ToolPac's Layout Manager will let you quickly rename multiple layouts using a find/replace, a single click builds a printable report of the drawings layouts, and a lot more !!!
”Boost
