AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Removing a Coordinate System
3 REPLIES 3
cedwards8511
2700 Views, 3 Replies
Does anyone know how to remove a coordinate system from a drawing? I have a drawing that wasn't created with coordinates but somehow got one assigned to it. When I try to remove it, I have to assign something to drawing. You can't just leave the code area blank or it just remembers what was there before. Help...
3 REPLIES 3
in reply to: cedwards8511
This seems to work.
(setq cscode "")
(ade_projsetwscode cscode)
Copy those two lines to the command line with the parentheses if you don't
know lisp.
Murph
wrote in message news:5106996@discussion.autodesk.com...
before. Help...
cedwards8511
Thank you...that seems to do the trick.
FYI: you can use a period (.) to un-assign a system to a DWG.
Scott
”Boost
