AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Referencing a Shapefile into an AutoCAD drawing
1 REPLY 1
mvolz47
452 Views, 1 Reply
I was wondering if there was a way to reference an ESRI ArcView shapefile into an AutoCAD drawing without having to import (convert) the shapefile into AutoCAD entities. I was hoping to be able to bring in a "snapshot" of the shapefile into the AutoCAD drawing. I would like to be able to do this because the conversion process between a shapefile and an AutoCAD file is time consuming. Has anyone encountered this problem before? Is this capability built into AutoCAD Map or would you need an add-on package? Any help or hints on this topic would be greatly appreciated. Thanks in advance.
1 REPLY 1
in reply to: mvolz47
No you definitely cannot reference a shapefile
or other external file format.
It isn't that time consuming to convert is it? How
big are your files? If there are many, you could use a script for the
conversion, and run it overnight...
Cheers,
David
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
I
advance.
”Boost
