AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Raster image clip
6 REPLIES 6
pathfinderNE
999 Views, 6 Replies
Raster image clip
How do you clip a raster image when brought in using Display Manager Add Data?
6 REPLIES 6
JoAnn_Hogan
in reply to: pathfinderNE
When you select the image does the ribbon change?
If this post solved your issue please mark as solved and Kudos are always welcome 😃
Jo - Ann
Twitter: @JoAnn_Hogan
Revit Architecture Certified Professional / Revit Structure Certified Professional / AutoCAD Certified Professional
pathfinderNE
in reply to: JoAnn_Hogan
Yes parts of the ribbon go blank.
Dennis Strauch
General Manager
Pathfinder Irrigation District
308.623.1022
JoAnn_Hogan
Is there any "new" commands in the ribbon?
Jo - Ann
pathfinderNE
I did not see any new when I added the image.
Dennis Strauch
General Manager
308.623.1022
foxeec
When you attach an image through FDO, do the following:
Zoom in to the area you want clipped.
Right-click on the name of the image in the Display Manager
Choose 'Resample image'
this will clip everything outside of the current zoom level, and should make the image regenerate quicker when panning/zooming.
if you want all of the image back, just zoom far enough out, and repeat the 'resample image' choice.
Lorrie
pathfinderNE
in reply to: foxeec
That helps thank you.
Dennis Strauch
General Manager
308.623.1022
”Boost
