AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Raster Extension Options > Memory
7 REPLIES 7
Message 1 of 8
875 Views, 7 Replies
I am having a problem with the memory limit setting. I am setting my
memory limit to be 2056 MB, but it will not keep the setting. I can
change it and get a message stating that the change will not work until
I restart Civil 3D (Map 3D). When I do that, it goes back to a 204 MB
limit instead of the 2 GB I want.
How can I get Civil (Map) to remember this setting?
EB
Win7 Pro 64-bit
Civil 3D 2010 SP2
4GB RAM
7 REPLIES 7
Message 2 of 8
Try setting it to 2048 and see it it stays.
Murph
http://map3d.wordpress.com/
"Srayos Endbringer" wrote in message
news:6293993@discussion.autodesk.com...
EB
Win7 Pro 64-bit
Civil 3D 2010 SP2
4GB RAM
Message 3 of 8
Doesn't work. It doesn't matter what I set it to, Civil (Map) resets it
to a strange number. This time is 206.4275 MB. I didn't have this
problem before, but now when I need to insert a large MrSid that is 2.5
GB this 200 MB limit is making it impossible to do any work. In fact, it
is taking almost 3 minutes just to open a drawing I've opened before in
about 15 seconds.
I'm watching the task manager memory of acad.exe and it went from ~280
MB down to ~20 MB, then climbed up to around 90 MB. I have no idea
what's going on as I haven't changed anything on my system. This same
drawing used to make acad.exe take up to 1.3 GB of RAM, now it's not
doing that. I don't get it and I've got a deadline for Wednesday before
the holiday starts to get this map out.
ARGH.
EB
Win7 Pro 64-bit
Civil 3D 2010 SP2
4GB RAM
Message 4 of 8
OK, now I can't plot anything with raster images. Civil (Map) is
refusing to use more than 204 MB of memory for raster images and I get a
message saying that AutoCAD is running out of memory. I'm using Windows
7 Pro 64-bit, so it should be using up to 4 GB before I run out of memory.
I've restarted Civil and it didn't fix it. I reset the computer and
that didn't do it either. What the heck is going on?
EB
Win7 Pro 64-bit
Civil 3D 2010 SP2
4GB RAM
Message 5 of 8
Have you cleaned out the users temp folder and the map cache folder?
Murph
news:6294587@discussion.autodesk.com...
EB
Win7 Pro 64-bit
Civil 3D 2010 SP2
4GB RAM
Message 6 of 8
I started a SR and got a reply. The Raster Memory limit has a max
setting of 2047 MB. You cannot try a higher number or it will reset it.
It would have been nice if the software gave a warning about that
instead of just letting me pick it and then resetting it every time.
Also, I knew about RASTERTHRESHOLD and RASTERPERCENT, but I did not know
that RASTERTHRESHOLD could go above 100. I set it to 150 and my plot
worked.
EB
Win7 Pro 64-bit
Civil 3D 2010 SP2
4GB RAM
Message 7 of 8
2047 and here I said try 2048. Off by one just like with the lottery
numbers. : (
Murph
news:6294768@discussion.autodesk.com...
worked.
EB
Win7 Pro 64-bit
Civil 3D 2010 SP2
4GB RAM
Message 8 of 8
juanpsmiranda
Olá, estou tendo problemas de memória zerada no meu autocad civil 2010 , windows 07 64bits.
no campo RAM settings  - physical RAM está 0 MB
como faço pra resolver isso?será que é problema do autocad? ou do windows 7 64bits
”Boost
