AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Question on Creating Polygon Topology...
1 REPLY 1
debmurphy
132 Views, 1 Reply
I am a former ArcCAD user trying to figure out how to use my current data in Map...
Does Map have a way of reading in AutoCAD text values when creating polygon
topology so that external data can be linked or...can this only be done if the values
are stored as block attributes?
thanks, Deb
1 REPLY 1
in reply to: debmurphy
Deb,
it's not related to topology creation, but both is possible (with text
objects and block attributes). Please, check Map's documentation on the
'Generate Links' command for more details on how to do that.
Marion Pietsch
WW Support & Services
Autodesk GIS Product Support
> data in Map...
> polygon
> done if the values
> thanks, Deb
”Boost
