AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Query query..!!
3 REPLIES 3
neilyj666
515 Views, 3 Replies
Query query..!!
I have brought in a raster ASC file (X,Y,Z) and am only interested in the red area (ultimately I want to create 1m contours layer) but cannot find a way to query the data to only show the red area.
Any advice??
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
3 REPLIES 3
Alfred.NESWADBA
in reply to: neilyj666
you have Civil3D, then it's easier to import the points as Civil3D-surface, then define a border to this surface (your red polyline) and set the style to show contours. The contours are also calculated with higher quality then (imho).
Good luck, - alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
neilyj666
in reply to: Alfred.NESWADBA
I'll agree to disagree on this as in my experience the contour layer (obtained via MAP tools) is far better then the same contours derived via a C3D surface.
Even though "..all contours are lies..", the MAP version looks a lot better
phil_borycens
You might be able to try:
in a text editor, manually deleting the other points outside of the extents
OR...
treat it as a point cloud (treat it as points), and this should allow for filtering out what you do not want
Phil Borycens
”Boost
