AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
query definition is empty
20 REPLIES 20
Message 1 of 21
mpe
1950 Views, 20 Replies
If I use Boundary Trim on some normal 2D lines and polylines in an new drawing based on map2Diso.dwt and then switch to a layout, AutoCAD Map 3d 2013 gives me the message "query definition is empty". Don't know why or how to get rid of it, but it is really bothering us.
Who can give me a hint?
20 REPLIES 20
Message 2 of 21
antoniovinci
in reply to: mpe
Does it occur only using the "map2Diso" template, or with other .DWTs as well..?
Message 3 of 21
mpe
in reply to: antoniovinci
It doesn't seem to matter what template I use.
Message 4 of 21
antoniovinci
in reply to: mpe
If you start from scratch (no template, empty drawing) add a couple of lines, then apply _MAPTRIM and switch to layout: what happens?
Message 5 of 21
mpe
This time, after starting with no template metric, the message appears directly after the MAPTRIM command ended.
Message 6 of 21
antoniovinci
in reply to: mpe
What about installing this..?
Message 7 of 21
mpe
I am already working in SP2.1
Message 8 of 21
antoniovinci
in reply to: mpe
Last effort, then I'll give up, sir.
Open a Sample drawing, e.g. CHROMA.DWG, draw something and _maptrim it: what's goin' on?
Message 9 of 21
mpe
Thanks for your effort so far.
Still the same message after the MAPTRIM command.
Message 10 of 21
antoniovinci
in reply to: mpe
Ideas over, I cannot reproduce your issue to solve it: seems like you gotta reinstall Map3D, sir.
Message 11 of 21
mpe
Thanks for your help. Reinstalling won't solve this. Several colleagues are experiencing the same issue.
Message 12 of 21
olivier.eckmann
in reply to: mpe
I can reproduce this on my MAP 2013 64bit French.
Just launch MAPTRIM command and press Esc on keyboard produces an alert message "La définition de requête est vide."
I thinks that generates no error just bad info.
Olivier
Message 13 of 21
Alfred.NESWADBA
in reply to: mpe
Sorry to say, same happens on my Map3D 2014 German.
But as Olivier already stated, I see that as just a message without any negative impact to the drawing.
@Antonio
time to upgrade, otherwise you miss this bug again and again ... 😉
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 14 of 21
Koesti
in reply to: Alfred.NESWADBA
I try the URL: http://geoservices.brgm.fr/geologie and it work for me with 2015.
Can you please let me know which OS you are using and it could be helpful to get the build number.
To get the build just type (map_build) to the command line and enter, please send me the result.
I would be also interesting if Map 2015 is always installed on the same PC as Map 2014.
Regards
Brigitte
Brigitte Koesterke
Technical Support Senior Specialist
Message 15 of 21
Alfred.NESWADBA
in reply to: Koesti
Hi Brigitte,
command _MAPTRIM and then switching to layout1 does show the same message in the German release of Map3D 2015 too ... and yes, on that workstation I have installed Map3D 2014 too.
But I don't understand what you like to achive with the link to the WMS-server?
- alfred -
Alfred NESWADBA
Message 16 of 21
Koesti
Hi Alfred,
sorry, the last post is referring to the WMS issue; I wasn't fast enough to remove it.
But for the "Maptrim" issue I search in our database and can't find any documentation.
So I will perform some additional tests and log it to our development team for further investigation.
regards
Brigitte
Brigitte Koesterke
Message 17 of 21
Alfred.NESWADBA
in reply to: Koesti
Hi Brigitte,
That's how support is working here in the forums ... 😉
BTW: the message mentioned here is not beautiful, but at least it does not influence the work process or the data, so the WMS-problem, or other problems like MAPFEATUREMERGE failures (>>>click<<<) have to have a higher priority!
- alfred -
Alfred NESWADBA
Message 18 of 21
Koesti
Hi Alfred,
I agree, it is only warning, but should give more information about the reason.
This issue has been raised to the development team for investigation.
I agree also that the other issue is more important and will work on this.
regards
Brigitte
Brigitte Koesterke
Message 19 of 21
Alfred.NESWADBA
in reply to: Koesti
Hi Brigitte,
I have to redefine my wording above just to make sure it's more clear what I really meant:
    >> I wasn't fast enough to remove it
I wanted to say: this support here in the forum is so fast that nobody has time to remove a message a few minutes later.
Sorry for my words that could be interpreted in another way, which I didn't want.
- alfred -
Alfred NESWADBA
Message 20 of 21
cynwalker
I'm now using Map 2020 and still getting the same message.......so much for acad support
”Boost
