AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
QUERY, ALTER PROPERTIES IF STATEMENT troubles
0 REPLIES 0
Message 1 of 1
241 Views, 0 Replies
Hello all,
I'm unable to solve this problem. I'm running a query on some pipelines to which i'm setting a Alter Properties to change the layer based on Object Data. I want to incorporate a IF statement so that if ("company name" = SHELL) call the layer SHELL - SUBSTANCE else call the layer PIPELINE - SUBSTANCE.
I tried these plus numerous others. Any suggestions, Thanks so much!
(if(:comp_name@pipeline_pl_joined="SHELL") (STRCAT :comp_name@pipeline_pl_joined "-" :sub_1@pipeline_pl_joined) (STRCAT "PIPELINE - " :sub_1@pipeline_pl_joined))
(if(:comp_name@pipeline_pl_joined=SHELL) (STRCAT :comp_name@pipeline_pl_joined "-" :sub_1@pipeline_pl_joined) (STRCAT "PIPELINE - " :sub_1@pipeline_pl_joined))
Daniel Martin.
0 REPLIES 0
”Boost
