Blair,
even if you can link several table records to one object in the drawing I
wouldn't recommend to do that, because of what you're just experiencing. It's
better to have only record linked to one object and having a unique ID in the
table.
I couldn't tell you how to solve this best as I don't know your data and
requirements, but you should try to figure out a way to manage it differently.
Marion Pietsch
WW Support & Services
Autodesk GIS Product Support
Blair Nixon wrote:
> When performing a report query on entities with multiple database records
> attached to them, only the first record is exported to the report file. For
> example, if I attach 3 records in Access to 1 polygon in AutoCAD and then
> perform a report query on this entity, only the first record is exported to
> the new file. The other 2 records are ignored. If I display attached
> records to the same entity through a dataview, all three are highlighted.
> Is there a way around this or do you have any advice on how to overcome this
> problem.
> Thank you, in advance.
> Blair
> nixonb@canam.com
