AutoCAD Map 3D General Discussion
Active Contributor
0 Kudos
Post 1 of 3
Qleader
140 Views, 2 Replies
07-16-2012 10:09 PM
Hi, could someone please tell me what the setting is to create a space between the leader line and the text.
Thanks in advance
Valued Contributor
5 Kudos
Post 2 of 3
Re: Qleader
07-17-2012 10:20 AM in reply to: Ronaldo54
Try looking for "landing gap" in the TEXT area of the properties dialogue box if you've already created your leader/text (multileader). Or in your multi-leader style under the CONTENT tab.
If you are in dimension style, look under the TEXT tab for "offset from dim line"
Or try typing DIMGAP
Hope one of these gets whatyou need.
Civil 3D 2011
Windows 7 Prof. x64
HP Z400 Workstation
Intel(R) Xenon(R) CPU
W3550 @ 3.07GHz
6.00 GB RAM
Active Contributor
0 Kudos
Post 3 of 3
Re: Qleader
07-17-2012 04:06 PM in reply to: Maine-iac
Thank you my friend, DIMGAP did the trick! Couldn't find a 'landing gap' in the Text area of
Properties Dialogue box though!!
