AutoCAD Map 3D General Discussion
Board Manager
scott.sheppard
Message 1 of 15 (1,582 Views)
Project Parsec for AutoCAD Map 3D available on Autodesk Labs
1582 Views, 14 Replies
11-09-2011 10:42 AM
Project Parsec for AutoCAD® Map 3D 2012 software provides functionality that enables users to import and map GIS geometries and attributes to AutoCAD Map 3D industry models* from SDF, SQLite, and Esri® SHP and geodatabase files, as well as Microsoft® SQL Server® and Oracle® databases.
http://labs.autodesk.com/utilities/parsec/
Alternatively to posting in this thread, you can email labs.map3d.parsec@autodesk.com - whichever you prefer.
Scott Sheppard
Program Manager
Autodesk Labs
this doesn't work on map 3d 2012 enterprise
* Project Parsec does not work with AutoCAD® Map 3D Enterprise 2012 software.
Board Manager
scott.sheppard
Message 2 of 15 (1,577 Views)
Re: Project Parsec for AutoCAD Map 3D available on Autodesk Labs
11-09-2011 11:47 AM in reply to: scott.sheppard
Unfortunately shortly after the launch of our technology preview, our QA team found a serious problem that we wish to correct before obtaining feedback on the technology. In light of this, we have temporarily removed the installer from our download servers. Once we have corrected the problem, we will post the updated installer to the download server. When the new installer is available, I will post a blog article on It's Alive in the Lab. We apologize for the inconvenience, and thank you for your continued interest in technology previews for AutoCAD Map 3D.
Scott Sheppard
Program Manager
Autodesk Labs
Board Manager
scott.sheppard
Message 3 of 15 (1,545 Views)
11-15-2011 01:50 PM in reply to: scott.sheppard
The Project Parsec installer is now available for download. Thanks for your patience.
Scott Sheppard
Program Manager
Autodesk Labs
arnoldschwabe
Message 4 of 15 (1,433 Views)
12-09-2011 08:27 AM in reply to: scott.sheppard
So, I thought to myself, self, this Project Parsec would be cool to try. I downloaded the installer and tried to install it. I'm using Civil 3D 2012 and apparently it can't find it or doesn't recognize it as a Map 3D application.
Will this be available for Civil 3D or is it only going to be an add-on for plain Map 3D?
Board Manager
scott.sheppard
Message 5 of 15 (1,418 Views)
12-10-2011 10:02 AM in reply to: scott.sheppard
I believe it is only for AutoCAD Map 3D SP1.
http://labs.autodesk.com/utilities/parsec/supported_apps/
Scott Sheppard
Program Manager
Autodesk Labs
Alfred.NESWADBA
Message 6 of 15 (1,413 Views)
12-10-2011 10:51 AM in reply to: scott.sheppard
tried now with Map3D 2012 x64 Enterprise SP1 German.
First I installed it by starting project_parser_deu_x64.exe (tried also the default x64-exe)
Then I started Map3D, see the additional ribbon-part and tried to start "Convert to Industry Model" ==> my commandline says now (translated) _mapconverttomodel unknown command "MAPCONVERTTOMODEL"
So I searched for what happend to my machine and what's new and I think that file is new and found this DLL:
C:\Program Files\Autodesk\AutoCAD Map 3D 2012\Map_SubscriptionExtensions.dll
and as it's a DLL I tried to netload it (don't know if that is a managed-DLL, just worth to try it), the result in the commandline was:
netload Assembly kann nicht geladen werden. Fehlerdetails:
System.BadImageFormatException: Die Datei oder Assembly "file:///C:\Program
Files\Autodesk\AutoCAD Map 3D 2012\Map_SubscriptionExtensions.dll" oder eine
Abhängigkeit davon wurde nicht gefunden. Im Modul wurde ein Assemblymanifest
erwartet.
Dateiname: "file:///C:\Program Files\Autodesk\AutoCAD Map 3D
   bei System.Reflection.RuntimeAssembly._nLoad(AssemblyName fileName, String
codeBase, Evidence assemblySecurity, RuntimeAssembly locationHint,
StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean
forIntrospection, Boolean suppressSecurityChecks)
   bei System.Reflection.RuntimeAssembly.InternalLoadAssemblyName(AssemblyName
assemblyRef, Evidence assemblySecurity, StackCrawlMark& stackMark, Boolean
   bei System.Reflection.RuntimeAssembly.InternalLoadFrom(String assemblyFile,
Evidence securityEvidence, Byte[] hashValue, AssemblyHashAlgorithm
hashAlgorithm, Boolean forIntrospection, Boolean suppressSecurityChecks,
StackCrawlMark& stackMark)
   bei System.Reflection.Assembly.LoadFrom(String assemblyFile)
   bei Autodesk.AutoCAD.Runtime.ExtensionLoader.Load(String fileName)
   bei loadmgd()
For me it's not working and I didn't find a way (within a few minutes) to get it running.
Just as additional feedback: on Lab's -site of >>>Parsec - getting started<<< it ends with "and follow the on-screen instructions" ==> LOL. there are no on-screen instructions, there is no readme, there is nothing, not even how to get it started.
Also the overview telling me with Parsec I can import Map-GIS-geometries ... wow, I always thought I can do that without Parsec (and did it also in the past). I think if the descriptions works more out for what differences are between Parsec's import and FDO-Import the more people may try it (and give feedback). All what there is listed (thematic mapping by attributive GIS-data) could be done with Map3D also.
- alfred -
Alfred NESWADBA
DarrenP
Message 7 of 15 (1,398 Views)
12-12-2011 07:23 AM in reply to: Alfred.NESWADBA
tyronebk
Message 8 of 15 (1,299 Views)
02-14-2012 11:51 PM in reply to: Alfred.NESWADBA
I am getting the same problems, and then error, as Alfred but am not running enterprise. Map 3D 2012 SP1 installed from the Infrastructure Suite if that makes any difference.
New Member
ebonacina
Message 9 of 15 (1,232 Views)
03-21-2012 07:01 AM in reply to: scott.sheppard
Hello, yesterday I tried Project Parsec and all was ok. Today I have to uninstall AutocadMap3D because I had a disk problem where it was installed. The Autocad Map 3D install was OK but when I try to install Project Parsec I have this message:
Wath can I do, or which was my misstake?
Thanks in advance for any suggestion.
Sorry for my bad English!
Enrico
New Member
ebonacina
Message 10 of 15 (1,228 Views)
03-21-2012 07:04 AM in reply to: ebonacina
AutoCAD Map 3D 2012 is already configured with Project Parsec
Enrico
