AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Project Basejump for AutoCAD Map 3D Now Available on Autodesk Labs
65 REPLIES 65
Message 1 of 66
scott.sheppard
8468 Views, 65 Replies
Project Basejump is a free technology preview on Autodesk Labs:
http://labs.autodesk.com/utilities/basejump/
You can try inserting from Bing as a base layer in your AutoCAD Map 3D drawings. Please try it and reply to this thread.
Scott Sheppard
Program Manager
Autodesk Labs
Autodesk, Inc.
65 REPLIES 65
Message 41 of 66
When I try to "Add to Map" I get the error message as shown in post 33 but for a split second before that error message shows up an error about "Stylizing" flashes up then disappears.
I would really like to use the Bing map service, it looks great, but can anyone identify my problem?
The same thing happens to a another collegue. Cheers Caleb
Message 42 of 66
gluckett
I have found if I don't set my map coordinate system, I get these kind of errors.
Message 43 of 66
Neither setting or not setting the coordinate system makes any difference.
Cheers
Caleb
Message 44 of 66
in reply to: andrewpuller3811
Andrew, give Trend Micro "Office Scan" a try, I have not had any problems using it with this add on.
Robert Rien
Message 45 of 66
antoniovinci
Basejump retired, even 2 days before the natural death: what's happening in Autodesk Labs'..?
Message 46 of 66
Project Basejump will continue to work until June 30 for those who have it. I retired the Autodesk Labs web pages early so that new users do not download, install, and have the rug pulled out from under them only 2 days later. That would have been frustrating for them.
Scott Sheppard
Program Manager
Autodesk Labs
Autodesk, Inc.
Message 47 of 66
gperego
in reply to: scott.sheppard
Hi Scott,
We hope in the next days to find a new brave technology, to use Web geographical data in Map 3D! 🙂
Many thanks
Giovanni
Message 48 of 66
in reply to: gperego
Hello, gperego
Have you ever found the solution for this proxy access with user authentication?
I'm having the same problem.
Tried the 'all_proxy' env variable but, of course, does't work for it uses authentication
TIA,
raa
Message 49 of 66
I along with the other engineer here have been using project Basejump extensively for the past two months - now that it's gone, suffice to say, we miss it sorely. For what it's worth, consider this feedback a resounding cry to bring it back, we got so used to it, having to go hunt for ortho satellite images is going to be a huge pain. It's been an amazing tool, I feel almost lost without it.
Message 50 of 66
rbunner
So very sad that Project Basejump is gone.  I have been using this for projects - now what do I do???  Smiley Frustrated
Message 51 of 66
I definitely feel your pain [cid:image001.jpg@01CD586B.EA37E8D0] Kenneth Casperson_________ Engineering Technician 2916 W M-28 Dafter, MI, 49724 * Email: kcasperson@cloverland.com * Phone: 906.632.5145 [cid:image002.jpg@01CD586B.EA37E8D0]Cell Phone: 906.440.3461 ________________________________ CONFIDENTIALITY: This email (including any attachments) may contain confidential, proprietary and privileged information, and unauthorized disclosure or use is prohibited. If you receive this email in error, please notify the sender and delete this email from your system.
Message 52 of 66
gluckett
For those missing Bing in the background, think about OpenStreetMap (the defacto map for Apple)
Simply add a new WMS layer in Display Manager:
Data > Connect to Data > Add WMS Connection
  1. Add http://wms.latlon.org/?layers=osm and version as 1.1.1
  2. Cick Connect
  3.  Click Login
  4.  Check OpenStreetMap mapnik
  5. Click Add to Map
You will the openstreetmap.org data from latlon.org
Nice touch.  For those of you using Autodesk Infrastructure Map Server (mapguide) you can do this, even for you BASIC WEB LAYOUTS where you don't want to use Flexible web layouts
gordon
Message 53 of 66
antoniovinci
in reply to: gluckett
Thanks for the tip, G.
If I load the Latlon layer in a WMS opensource client, I can see all the beauty of the Bing imagery, by setting it like this.
What about you to try the same in Map/Civil 2013, instead of the OSM streets?
Message 54 of 66
swt-gis
Is latlon.org a reputable service provider? I can not access latlon.org from our intranet because
latlon.org ist listed in our blacklist of “Trend Micro OfficeScan”.
Jens
Message 55 of 66
gperego
hi Gordon,
Great suggestion!
I just published a post in my Blog for italian users of Map 3D
http://www.bimacademy.it/gis/2012/07/usare-openstreetmap-con-autocad-map-3d/
You can read it in english language using the Google button to translate in the left column of the Blog
Many thanks and regrads
Giovanni - GimmiGIS - Perego
Message 56 of 66
pmascaro
Thanks, gluckett!
It works for me as long as I'm set to V 1.1.1, however when I zoom into a size and resample I get a black tile.... Anyone else having this problem?
-Paul
Message 57 of 66
in reply to: pmascaro
Yes. I get the same problem. It looks fine when zoomed out to world level, but how do I resample as I zoom in?
Message 58 of 66
gluckett
Just right-click in the Display Manger and click Update.
Message 59 of 66
cderrico
The OSM WMS is looks like a good alternative.  Thanks for the tip!
I can see the services, but when I try to add them to the map I get:
WARNING: The problems below were found applying style(s) to element osm:
Coordinate transformation failed for this feature.
Any thoughts?
C
Message 60 of 66
gperego
The best way to use OpenStreetMap data is to connect before a georeferenced map.
Data works well if you assign a coordinate system before connecting to WMS.
It is important also to use Proxy options,otherwise Proxy can stop connection
Regards
Giovanni
”Boost
