AutoCAD Map 3D General Discussion
0 Kudos
Post 51 of 66
Re: Project Basejump for AutoCAD Map 3D Now Available on Autodesk Labs
07-02-2012 01:01 PM in reply to: scott.sheppard
I definitely feel your pain [cid:image001.jpg@01CD586B.EA37E8D0] Kenneth Casperson_________ Engineering Technician 2916 W M-28 Dafter, MI, 49724 * Email: kcasperson@cloverland.com * Phone: 906.632.5145 [cid:image002.jpg@01CD586B.EA37E8D0]Cell Phone: 906.440.3461 ________________________________ CONFIDENTIALITY: This email (including any attachments) may contain confidential, proprietary and privileged information, and unauthorized disclosure or use is prohibited. If you receive this email in error, please notify the sender and delete this email from your system.
Valued Mentor
74 Kudos
Post 52 of 66
07-03-2012 09:49 AM in reply to: kcasperson
For those missing Bing in the background, think about OpenStreetMap (the defacto map for Apple)
Simply add a new WMS layer in Display Manager:
Data > Connect to Data > Add WMS Connection
  1. Add http://wms.latlon.org/?layers=osm and version as 1.1.1
  2. Cick Connect
  3.  Click Login
  4.  Check OpenStreetMap mapnik
  5. Click Add to Map
You will the openstreetmap.org data from latlon.org
Nice touch.  For those of you using Autodesk Infrastructure Map Server (mapguide) you can do this, even for you BASIC WEB LAYOUTS where you don't want to use Flexible web layouts
gordon
194 Kudos
Post 53 of 66
07-04-2012 12:40 AM in reply to: gluckett
Thanks for the tip, G.
If I load the Latlon layer in a WMS opensource client, I can see all the beauty of the Bing imagery, by setting it like this.
What about you to try the same in Map/Civil 2013, instead of the OSM streets?
1 Kudo
Post 54 of 66
07-05-2012 06:05 AM in reply to: gluckett
Is latlon.org a reputable service provider? I can not access latlon.org from our intranet because
latlon.org ist listed in our blacklist of “Trend Micro OfficeScan”.
Jens
2 Kudos
Post 55 of 66
07-05-2012 06:09 AM in reply to: kcasperson
hi Gordon,
Great suggestion!
I just published a post in my Blog for italian users of Map 3D
http://www.bimacademy.it/gis/2012/07/usare-openstreetmap-con-autocad-map-3d/
You can read it in english language using the Google button to translate in the left column of the Blog
Many thanks and regrads
Giovanni - GimmiGIS - Perego
Valued Contributor
7 Kudos
Post 56 of 66
07-05-2012 07:30 AM in reply to: scott.sheppard
Thanks, gluckett!
It works for me as long as I'm set to V 1.1.1, however when I zoom into a size and resample I get a black tile.... Anyone else having this problem?
-Paul
Paul R. Mascaro
CAD Supervisor | Engineering Design
ENVIRON International Corporation
System: Dell 6800M, OS | MS Windows 7 64-bit SP1, CPU | Intel Core i7 Gen4 @ 3.00GHz Haswell 22nm, RAM | 32.00 GB DDR3 1600 MHz, Graphics | NVIDIA Quadro K5100M (8 Gig), HD | SSD Master, SS Hybrid Secondary
11 Kudos
Post 57 of 66
07-05-2012 12:51 PM in reply to: pmascaro
Yes. I get the same problem. It looks fine when zoomed out to world level, but how do I resample as I zoom in?
Caleb Baildon
Surveyor
Opus International Consultants Ltd
Greymouth, New Zealand
Civil3D 2015 - Windows7 64bit
Valued Mentor
74 Kudos
Post 58 of 66
07-05-2012 01:12 PM in reply to: cbaildon001
Just right-click in the Display Manger and click Update.
Active Contributor
0 Kudos
Post 59 of 66
07-05-2012 07:07 PM in reply to: gluckett
The OSM WMS is looks like a good alternative.  Thanks for the tip!
I can see the services, but when I try to add them to the map I get:
WARNING: The problems below were found applying style(s) to element osm:
Coordinate transformation failed for this feature.
Any thoughts?
C
2 Kudos
Post 60 of 66
07-06-2012 12:31 AM in reply to: kcasperson
The best way to use OpenStreetMap data is to connect before a georeferenced map.
Data works well if you assign a coordinate system before connecting to WMS.
It is important also to use Proxy options,otherwise Proxy can stop connection
Regards
Giovanni
