AutoCAD Map 3D General Discussion
gperego
Message 21 of 66 (794 Views)
Re: Project Basejump for AutoCAD Map 3D Now Available on Autodesk Labs
05-16-2012 03:22 AM in reply to: scott.sheppard
I think Basejump works very well.
In the next release, it should be useful to add Proxy informations, like in WMS and WFS connections...
Many thanks
Giovanni
PS: read my Blog article on Basejump Project
http://www.bimacademy.it/gis/2012/05/usa-le-mappe-di-bing-in-autocad-map-3d-e-civil-3d/
Valued Contributor tpc
Valued Contributor
tpc
Message 22 of 66 (789 Views)
05-16-2012 05:49 AM in reply to: scott.sheppard
OK. I got it to work in one drawing, but when I try to add it to another it's a no-go.
How can I get it to work in a specific county? I'm doing what it says but it really doesn't ask you much about location and specifics.
rbunner
Message 23 of 66 (787 Views)
05-16-2012 07:28 AM in reply to: scott.sheppard
I really like this - the clairity of the image is very sharp.  My problems that I am having when plotted landscape I loose the image clarity but portrait it's fine - very strange.  I also will have more than one viewport of a different area but when plotted the views are exactly the same - another strange senario.  Has anyone else noticed this??
Valued Contributor
TCARCAMO78
Message 24 of 66 (751 Views)
05-22-2012 11:27 AM in reply to: daniel.appert
I have installed the application several times and it still does not show on my mapconnect options. Any ideas? I have windows 7 64 bit.
Tony
CAD Manager
Tony Carcamo
CAD Manager
www.tonyscivil3dworld.blogspot.com
gperego
Message 25 of 66 (741 Views)
05-23-2012 02:23 AM in reply to: gperego
This may be a Proxy problem.
You can follow this solution:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=11794193&linkID=9240857
Regards
Giovanni from Italy
See my Blog on Autodesk Infrastructure solutions: www.bimacademy.it/gis
Valued Contributor
TCARCAMO78
Message 26 of 66 (735 Views)
05-23-2012 05:53 AM in reply to: gperego
Ok it finally showed up on my C3D 2013 after several tries. Works great.
Tony
CAD Manager
Tony Carcamo
CAD Manager
Member
dmulamba
Message 27 of 66 (699 Views)
05-31-2012 05:16 AM in reply to: scott.sheppard
How do you generate contours, button is always grayed; see attached.
antoniovinci
Message 28 of 66 (692 Views)
05-31-2012 05:57 AM in reply to: dmulamba
You cannot, the Bing's one is a plain raster, not a Dem...
Active Contributor
bobs
Message 29 of 66 (679 Views)
05-31-2012 03:18 PM in reply to: scott.sheppard
Considering that ESRI ArcGIS has had access to Bing Maps since it was called Virtual Earth, I think this is a great addition to Map3D and has been a much needed .  There is always going to be hiccups to work out but I hope that Autodesk can add this feature to the product permanently.  Cloud based services is becoming the trend in GIS and Autodesk should keep up with the times.
Great work by getting us this preview in the labs.  No compliants from me.  It works!  :smileyhappy:
Active Contributor
richard.denier
Message 30 of 66 (668 Views)
06-01-2012 08:42 AM in reply to: scott.sheppard
First of all "This is a very nice feature." This works very easy and fast. Now the down site. The imagery is not very accurate. We had issues with Google Earth imagery accurecy and hoped the Bing imagery would solve this. But no.
As you can see the buildings are way out of line (magenta line). Infact there is a shift of 185 by -300 meters.
Do I do something wrong here? I'm using a drawing with the NetherlandsRDNew coordinate system, same for the shape.
