AutoCAD Map 3D General Discussion
Board Manager
scott.sheppard
Message 1 of 16 (2,067 Views)
Project Artoo for AutoCAD Map 3D Available on Autodesk Labs
2067 Views, 15 Replies
05-31-2012 07:36 AM
Project Artoo for AutoCAD® Map 3D 2013 software is a free* technology preview that helps you perform geometry cleanup operations on geospatial data stores to improve the quality and accuracy of your geospatial data.
http://labs.autodesk.com/utilities/artoo/
Please trry it and reply to this thread. There is also a thraed in the Civil 3D forum for AutoCAD Civil 3D users who also use AutoCAD Map 3D.
Scott Sheppard
Program Manager
Autodesk Labs
New Member
warren.geissler
Message 2 of 16 (2,059 Views)
Re: Project Artoo for AutoCAD Map 3D Available on Autodesk Labs
05-31-2012 10:22 AM in reply to: scott.sheppard
Great idea - I have several clients moving data bak and forth in Map 3D in order to do drawing cleanup. This will help a great deal.
On the Zero Length Objects. I have an attached SHP file with multiple vertices at one location. Standard DWG cleanup will fix this on an AutoCAD Pline - but this does not seem to be the case here. I'm attaching a sample SHP file for you to test.
New Member
endest
Message 3 of 16 (1,967 Views)
06-04-2012 02:22 AM in reply to: scott.sheppard
After installed the Artoo x64, I cann't find the "new Geospatial Cleanup icon" on Tools tab.
Is there other method to open it?
Valued Mentor
gluckett
Message 4 of 16 (1,953 Views)
06-04-2012 07:39 AM in reply to: endest
At the command line type:
MAPGISCLEAN
Active Contributor
iam_doss
Message 5 of 16 (1,900 Views)
06-06-2012 08:56 AM in reply to: scott.sheppard
Hi, where can I get the available clean operation list for every kind of data source and layer? It seems there are some operations valid for line layers but no for polygon layers. Exists that list?
Active Contributor
iam_doss
Message 6 of 16 (1,849 Views)
06-15-2012 03:58 AM in reply to: iam_doss
Hi, somebody here?
Board Manager
scott.sheppard
Message 7 of 16 (1,827 Views)
06-19-2012 08:05 AM in reply to: iam_doss
Thnak you for your patience. I have alerted the team that this message has not yet been answered. Our Product Manager associated with the technology preview will be back in the office on June 21.
Scott Sheppard
Program Manager
Autodesk Labs
Active Contributor
iam_doss
Message 8 of 16 (1,821 Views)
06-19-2012 08:54 AM in reply to: scott.sheppard
Thank you for your answer. I will wait for.
Member
mark.christian
Message 9 of 16 (1,809 Views)
06-19-2012 03:48 PM in reply to: scott.sheppard
As you've found out, not all cleanup operations will work on all data sources.  In fact, some cleanup operations will only work on certain geometry types. Below is a list of available cleanup operations by geometry type:
For Lines:
  • Delete Duplicates
  • Break Crossing Objects
  • Extend Undershoots
  • Apparent Intersection
  • Snap Clustered Nodes
  • Zero Length Objects
  • Erase Dangling Objects
  • Erase Short Objects
  • Dissolve Pseudo Nodes
  • Simplify Objects
  • Weed Polylines
For Polygons:
  • Sliver Polygon Removal
  • Reform Polygons
For Points:
  • Correct Duplicate Points
Mark Christian
Industry Marketing Manager
Engineering, Natural Resources & Infrastructure
Active Contributor
iam_doss
Message 10 of 16 (1,804 Views)
06-19-2012 09:43 PM in reply to: mark.christian
Thank you
