problem with
problem with
david.cormerais
Message 1 of 8
problem with
david.cormerais
coloriage proprio.jpghello, as you can see on the jpg , i m trying to use the thematique representation of a table.
Autocad has some problem with the rainbow automatic colors, i have exactly the same color after the 20st name in the table.
Do you have any idea ?
Replies (7)
Message 2 of 8
Alfred.NESWADBA
You can define your own color range and that is not limited to 20 individual colors.
Another option is to define own predefined schemas like described >>>here<<<.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 8
david.cormerais
Hello , and thanks for your response,
i can't get the same windows as shown in your post.
this work was done with an access table for information
Message 4 of 8
Alfred.NESWADBA
select in the Map TaskPane the item "PARCELLE", then the above icon "Style" and that's where my screenshot starts on the left sided dialog.
If this looks different make show me your "Style" dialog.
You do have the polygonal geometry in the MS-Access table?
How did you connect to that?
- alfred -
Alfred NESWADBA
Message 5 of 8
david.cormerais
If i click on the style icon , nothing happened.
I have to select "1parcelle" then  right clic and then add a style >>> theme
once the style has been creating i can modifie it
Message 6 of 8
Alfred.NESWADBA
well, I understand, you don't have GIS-data like SHP or SDF or from a database like MS-SQL-Server or Oracle attached, your geometry is directly in the drawing and the MS-Access file is just linked to some objects in the drawing. I have not played this way for years now, so it was lost from my remembering.
And sorry, I guess there you can't modify anything for the color themes.
What you might do instead (means switching to new technology, and getting a lot more functionality): export your data as SDF and use the FDO-technology (using command _MAPCONNECT) to get the SDF-data displayed, to get the MS-Access data bound, then join them and create the thematic mapping this way.
If you are used to it it's minutes, if not I would spent some hours or a training, but with the result of a lot more flexibility and performance.
Good luck, - alfred -
Alfred NESWADBA
Message 7 of 8
braudpat
Hello David / Daemge
Please when doing Multi-Posts (US & French Forums), please give the Web links from the other forums !
http://cadxp.com/topic/42037-representation-thematique/page__gopid__237537
So when a good idea or solution is given, we will not lost our time ...
Regards, Patrice (I am not an Autodesk Advisor)
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 8 of 8
david.cormerais
Thanks for that explication
I will try to see if i can manage what you explain
Sincerly
