AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
problem with Nearmap image file & correct coordinate system
2 REPLIES 2
1388 Views, 2 Replies
Nearmap has provided an aerial image georeferenced in the same coord system as Google Earth (epsg:3785).  I found a Map 3D coordinate system WGS84.PseudoMercator (epsg:3857) which on web forums is equivalent to epsg:3785.  After loading the image into a dwg on the epsg:3857 coord system I then queried the image into a dwg file on an mga55 gda94 coord datum.
It rotated the image correctly but as we had survey located features in the drawing the image needed to be shifted a further 1.75 metres SW than the transformation that Map had performed.
My question is can anyone confirm that the Map epsg:3857 is indeed the same as epsg:3785?  Given I had to shift the image I suspect it isn't.
Nearmap have also suggested using an epsg:900913 coord datum but there isn't one in Map 3D.
2 REPLIES 2
antoniovinci
You can compare the EPSG contents here: as you can see in the "Retrieve code" report, the 3785 refers only to New Zealand.
About EPSG:900913 it's a funny way to portray the official EPSG:3857, check this out:
9 => G
0 => O
0 => O
9 => G
1 => L
3 => E
in reply to: antoniovinci
Thank you for the reply.  I went to the link & it is interesting that epsg:3785 only applies to the south island of New Zealand.  From correspondence with Nearmap & the image name (starts with epsg_3785) this is the datum they are using.  I would assume that Nearmap would know what they are doing but as our imagery is based on the south-east coast of Australia it might not be the correct datum to be using.
”Boost
