AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Problem with exporting to ESRI SHAPE
9 REPLIES 9
Message 1 of 10
537 Views, 9 Replies
I have some problems with exporting a drawing to the ESRI Shape format.
I have to create different SHAPEfiles from 1 drawing. In fact, every layer
must become a SHAPEfile.
So I wrote a program in VB. But VB doesn't support a MAPEXPORT command.
So I started using scripts.
And here is the problem :
The MAPEXPORT4 command is not working properly because when i export a
polyline containing arcs the shapefile containes several duplicated points.
In MAP 5 the MAPEXPORT command (command line driven) works well for point en
line SHAPEfiles but not for polygon SHAPEfiles. They are empty.
In MAP 6 the MAPEXPORT command (command line driven) does not support the
export of Object Data to the SHAPEfile. It does when you use a profile, but
i'm not going to make a profile for every layer i have to export .... I
need to be variable.
So, i have 3 questions :
1. When is Autodesk going to make a MAPEXPORT command in VBA or VLISP ?
2. When is Autodesk going to create good and stable commands fo the command
line ?
3. Does anybody have a solution for this problem ?
Thanx in advance...
Stefan
9 REPLIES 9
Message 2 of 10
Hi Stefan. I am not sure what you are doing wrong but MAPEXPORT in Map6 does support OD tables when exporting to shapefile (even without profiles). The OD tables as well as other properties, SQL links and attributes are found under the DATA tab>>>"Select Attributes" of the MapExport dialog box. Also the fact that every layer must become a shapefile is not an AutoDesk limitation, it is just the way that ESRI shapefiles are handled. ESRI shapefiles do not recognize layers as AutoCAD does, it only recognizes points, polygons, and lines. If your drawing contains primarily many polygons, it may be more efficient to attach an OD table containing a unique layer name to each groups of polygons belonging to that layer. You can then send out all the polygons in one export process and the shapefile layers will be defined by field name in OD table.
Message 3 of 10
I can only contribute one small piece of your puzzle. You mention a problem
with exporting polygons. Did you check the box (programmatically of course)
for "treat closed polylines as polygons" ?
Shawn (remove HAT to reply)
"Stefan" wrote in message
news:38FA8931C9757EA20CFFB85BFC90D18B@in.WebX.maYIadrTaRb...
> Hi,
layer
points.
en
but
command
> line ?
> Thanx in advance...
> Stefan
Message 4 of 10
Selliott,
I know it is possible to select the object data
with the data tab, but it is not possible when you use the command
line.
Try doing the following :
filedia 0
cmddia 0
mapexport
If you can find a way to specify you want to
export Object Data too, please tell me (and AutoDesk because they don't know it
either).
And I cannot change the way I'm working (every
layer a different SHAPEfile) because this was asked by the organisation I
writing the program for...
Thanx for helping ...
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Hi
Message 5 of 10
Shawn,
I checked this already many times, but it is checked.
I opened a case at the Autodesk Developpers Network and people of Autodesk
anwered that this is a known problem ...
Thanx for helping...
"Shawn Sumpter" schreef in bericht
news:8886D9AD58C2E9B51C76180B9A5E28CC@in.WebX.maYIadrTaRb...
problem
course)
> > Hi,
> layer
> points.
point
> en
the
> but
> command
> > line ?
> > Thanx in advance...
> > Stefan
Message 6 of 10
Sorry, wrote a little mistake :
try the following :
filedia 0
cmddia 0
-mapexport
the "-" sign is important ...
Hi
Message 7 of 10
Stefan,
I just tried exporting a dwg to a shp file from the command line like this.
As long as you have a profile saved (.epf file) and call it at the correct
place in the -mapexport command it works. Either you have a bad install of
Map6 or there is something else wrong in your program.
Murph
news:4F32CAB2665A648F4E76E2000A81D623@in.WebX.maYIadrTaRb...
try the following :
filedia 0
cmddia 0
-mapexport
Message 8 of 10
Murph,
I know it works with profiles, but i cannot make 50+ profiles every time
before I'm going to export to SHAPEfile. It should be done like it was in
MAPEXPORT of MAP4 and MAP5, but these don't work properly...
I think there will be only one way to make it work :
write a program myself to make a SHAPEfile.
(and sell it to Autodeks ;-))) )
Thanx anyway for your time ...
stefan
"Murph" schreef in bericht
news:601D54E7C7BFB709A792C89CAC469589@in.WebX.maYIadrTaRb...
> Stefan,
this.
> Murph
> try the following :
> filedia 0
> cmddia 0
> -mapexport
Message 9 of 10
hiramjr
I know exactly what you're talking about because we have the same problem here. We run routines (lisp/vba) to export objects + object data to shape files. All worked fine until the migration to 2004. Now, for reasons unknown, a very important prompt (i.e. od table name) is missing from -mapexport.
I agree that going to a saved profile is not the answer. Going backwards to mapexport4 isn' the answer either because sometimes it works and sometimes it doesn't. Putting the prompt back into the command is the right answer.
oh well...
Eric Smallwood
Message 10 of 10
frankin4
I too have issues with closed polygons in Map. The first of which was sometimes easily(?) solved. When you make a polyline and force it to close (c) it doesn't REALLY close. For screen appearance sake it will draw the required segment to close. When you export out the "closed" polygon, it will not show. Long story short, you may need to rethink your polygon creation process. Run all the cleaning options with the appropriate tolerances. The other issue is island polygons, which still don't seem to work quite right. I usually end up exporting to a coverage, clean in ArcInfo, and export out to shape.
”Boost
