AutoCAD Map 3D General Discussion
Active Contributor
TATA_JUNE2007
Message 1 of 4 (330 Views)
Problem with AIMS 2012 64 bit on Windows 2008(64bit) server
330 Views, 3 Replies
10-16-2012 04:49 AM
Problem with Autodesk Infrastructure Map Server 2012.
I have installed AIMS 2012 64 bit on Windows 2008 server 64 bit. After Installation, I found that it has installed only Map Server & Extension only. But studio has not been installed which contain all the FDO as well.
Anyone help what is the way forward to install all three components on 64 bit Windows 2008 server?
Issue with AutoDesk India - No clue on any issue!!!
Anand
Robert_Fritz
Message 2 of 4 (317 Views)
Re: Problem with AIMS 2012 64 bit on Windows 2008(64bit) server
10-16-2012 06:27 AM in reply to: TATA_JUNE2007
Hi Anand,
can't remember the details anymore but Studio is a sperate installation package. You didn't mention why Studio wasn't installed - did you run Studio installer? It should be in a subfolder in the installation image für AIMS.
Studio is a client application - you wouldn't install it on a server but on a client such as XP or Win 7 machine.
Rob
http://raumpatrouille3d.blogspot.ch/
Active Contributor
TATA_JUNE2007
Message 3 of 4 (310 Views)
10-16-2012 07:50 AM in reply to: Robert_Fritz
Yes Rob,
AIMS 2012 contain all modules together and selectable to install sometime. However, as you suggested, I have installed studio separately and it has done.
Thanks really
Furthermore, now I and getting another message while login to Studio:
Message is – FastCGI must be properly configured before attempting to connect to Map Server. Any light on this please?
Anand
Robert_Fritz
Message 4 of 4 (294 Views)
10-16-2012 11:07 PM in reply to: TATA_JUNE2007
Hi Anand,
regarding the error message - I put the follwing into Google and got a (promising) hit: ""FastCGI must be properly configured" mapguide".
http://adndevblog.typepad.com/infrastructure/2012/04/install-autodesk-infrastructure-map-server-2013...
If it doesn't help to solve the problem - read through the AIMS Installation&Configuration Guide and check if everything has been installed properly. If the issue persists open a new thread in the discussion list,
Rob
