AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Problem Saving Map Coordinate System
2 REPLIES 2
ord36797
487 Views, 2 Replies
Hi everyone, I'm posting for one of our users...Please advise a way of saving the 'Map Coordinate System' on a specific drawing? - For example, I need to use Coordinate System MGA-55 when working on an Australian Project, and UTM84-39N when working on a Kazakh Project, however, if I set my coordinate system to MGA-55, then save my drawing, the Coordinate system resets to UTM84-39N when I reopen the same drawing (it appears not to be saved with the drawing). I'm Using 'AutoCAD Map 3D 2012 (64bit) running on Windows 7. Thanks!
2 REPLIES 2
antoniovinci
in reply to: ord36797
Before saving, try to force the current CRS thru the _ADESETCRDSYS command, sir.
ord36797
Hi antoniovinci Smiley Happy
Email from my very satisfied colleague...
"This post has provided the solution, and I am now able to set templates for the various Projects I work on. Thanks very much for your assistance."
”Boost
