Out of curiosity, did you run through that Map tutorial and get the same results? I went through the tutorial once more and noticed that many of the entries were joined, however, at some point the data seemed to 'stick' and the word "little" was sub'd into the 'owner name' field for the remainder of the potential joins. If it's a version problem in Access or something, I guess I have to deal with it. We have version 2002 and I don't know what versions are available since then. I will create a new table in a blank database, and create new polygons with a join-key to that database. If that will run successfully, I suppose you are right. Thank you.
I didn't think about trying the join in Arc. Maybe I'll take some data I've joined successfully in Arc and try it out in ACAD. I'm pretty new to databases, but I'm also kind of consumed by it all now. Lately all of my spare time is going into learning what I can about databases and tying them to drawing entities. Sadly, I don't even know what end I'll reach, but I've found several ways to report valuable information for a job and create exhibits to relate it to project team.. Anyway, have a great weekend.
Sam
