This one's a stinker.
I'm using AutoCAD Map 3D 2009.
I've created a simple drawing in CAD that contains a cropped JPEG, a two toned hatched polygon in behind it two MTexts overlaying all.
I cannot view them in either normal plotting, pdf format, jpeg format and even dwf.
I've increased the ram used in the "Raster Extension Options" (2000 MB), I've set the plotting in the "Process Document" to "...In computer", I've saved it in older formats (2000/2004/2007), I've placed the drawing on both our public drives as well as the local, I've adjusted the "Raster and Shaded/Rendered Viewports" & "OLE" settings in the "Device and Document Settings" (None to Best). Not to mention the other variations in the plot menu.
I've tried everything I can think of and have read through several threads here and nothing works.
What drives me nuts about this, is that I'm able to print from a layout with no problems a 3D drawing, with 2D hatching, an extensive title block with hatching and a secondary overall viewport (minimal detail) in the main viewport area.
Any ideas?
Toggle on/off MAPPLOTTRANSPARENCY, type it at the command line. Make sure you have all the updates/service packs for 2009.
Still didn't work. the MAPPLOTTRANSPARENCY didn't actually do anything, had to use "Transparency" at the command line, then I was able to toggle it.
Any other suggestions?
have you tried to convert the image to e.g. TIFF, reassign it to your drawing and plot this?
And one more idea: look for service-packs ... >>>here<<<
- alfred -
Either I already have all three patches or the downloads are corrupted. I've decided to give up as I'm fairly certain if I were to spend any more time on this I'll have to go for a psychotic break rather than a coffee break.
I appreciate your suggestions and the time you've given me.
Have a good one.
Have you tried going to properties/custom properties in the plotter settings and lower your resolutions. They may be too high for what you are trying to do. I know this has worked with PDF in some cases.
John
