AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
polylines and object data
2 REPLIES 2
svest_2001
326 Views, 2 Replies
I need to change the direction of polylines but want to keep the object data attached. I've tried plrev.lsp but the object data does not stay with the polyline once the direction s reversed. Any suggestions will be appreciated.
2 REPLIES 2
in reply to: svest_2001
A simple way would be offset or copy the pline, run plrev.lsp then the
copyod.lsp in the MAP sample folder to copy the OD back and erase the copied
pline.
Murph
http://mappingitout.blogspot.com/
wrote in message news:5328290@discussion.autodesk.com...
appreciated.
You can have your task done of reversing the polyline direction and
retianing the object data. By using command "GT_Flip" which
is in our product "GeoTools". You may want to give this a try and see for
yourself.
For a FREE 30 days evaluation download visit our website at
http://www.4d-technologies.com/geotools
Here is a short description of the command "GT_Flip" along with the GUI
Reverses the direction of the polyline vertices. This command preserves the
handle (see below for conditions) as well as any extended entity data that
is stored with the polyline or with each or any of its vertices (in case of
heavy weight polylines).
Sanjay Jamalpur
- Four Dimension Technologies
[www.4d-technologies.com]
- Get GeoTools, Work smarter: www.4d-technologies.com/geotools
- Free Lisp downloads @ TechCenter: www.4d-technologies.com/techcenter
appreciated.
”Boost
