AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Polyline with arc doesn't load properly into FDO data source
1 REPLY 1
tmblackflag
341 Views, 1 Reply
Hello there,
I have some polylines which i am wishing to load into Oracle FDO. When the polyline with an arc is converted to a polygon it slightly changes shape. I'm talking about 2-3 square feet on the area of an average 2D polyline.
Is there anyway to load these polylines with more precision?
1 REPLY 1
antoniovinci
in reply to: tmblackflag
You should not convert anything, sir.
If a mixed (i.e. lines + arcs) pline is closed, then the _MAPEXPORT command creates a shapefile with perfectly rounded arcs.
You have only to check "Treat closed polylines as polygons" in the Options window of that command.
”Boost
