AutoCAD Map 3D General Discussion
Member
0 Kudos
Post 1 of 5
Polyline to polygon to split polygon?
578 Views, 4 Replies
08-20-2012 12:35 AM
I have a rather complex net of roads and parking lots in the shape of a hatched polyline (basically a whole city). I now want to create a polygon from this net, which I later on want to be able to edit and split into a number of polygons.
Anyone with experience from that sort of operations?
194 Kudos
Post 2 of 5
Re: Polyline to polygon to split polygon?
08-20-2012 01:55 AM in reply to: goran.klensmeden
My humble advice: _MAPEXPORT the N layers (linear, polygon, and so on) to N shapefiles, then perform that kind of boolean operations in the opensource Qgis, sir.
Member
0 Kudos
Post 3 of 5
08-22-2012 10:34 PM in reply to: antoniovinci
Thank you!
I´ve been leaning towards that solution, but I really wanted to be able to solve it without exporting/importing. We´ll see how that works out! :-)
/ Göran
1,210 Kudos
Post 4 of 5
08-23-2012 03:18 AM in reply to: goran.klensmeden
I even don't understand the job.
As I understand you have a line-theme describing streets, from that you want to create a polygonal theme? That returns the area between the street-lines (if the area is closed) .... does that make sense? Is that what you plan to do or what am I missing?
- alfred -
Alfred NESWADBA
Member
0 Kudos
Post 5 of 5
08-23-2012 05:09 AM in reply to: Alfred.NESWADBA
@ALfred: Exactly! MAybe I expressed it alittle bit blurry, though. At the moment Í´m working with a different way of solving it by exporting the dwg to TAB and then use MapInfo. Works fine so far.
