AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Plotting to PDF - cant read text
2 REPLIES 2
Brandon2929
1009 Views, 2 Replies
Im having issues when plotting a PDF.  Im plotting using the DWG to PDF.pc3.  The text in the CAD file looks awesome, clean and crisp.  When I send it out to a PDF and I cant read the text.   Its being plotted at custom paper size - 72x72 as requested.  A PDF is attached.  Any suggestions would be appreciated!!
2 REPLIES 2
RyanCamick
in reply to: Brandon2929
I can't find any problem text when I look at your document.  Could you provide a screenshot so we can see what you see, and identify somehow the area of the PDF you are looking at?
Ryan
bob31clark
Make use of repair pdf file corrupted files.
Tool can recover text, graphics, hyperlinks and object forms used in the document.
”Boost
