I am attempting to plot using a map book drawing with a utility map and landbase file attached.
Once I select a map, and hit view map sheet, the query begins, but I get a 2 error message dialog box reading
Can't check objects intersection.
Can't calculate object extents.
AutoCAD error: eNotImplementedYet
ACAD_PROXY_ENTITY- handle ff89
Message code: 1914
What is going on? I can still plot the map, but I can't do multiple plot sets and walk away with this error message popping up on each one.
Thanks!
