AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Plot errors using plot map set function
2 REPLIES 2
328 Views, 2 Replies
I am attempting to plot using a map book drawing with a utility map and landbase file attached.
Once I select a map, and hit view map sheet, the query begins, but I get a 2 error message dialog box reading
Can't check objects intersection.
Can't calculate object extents.
AutoCAD error: eNotImplementedYet
ACAD_PROXY_ENTITY- handle ff89
Message code: 1914
What is going on? I can still plot the map, but I can't do multiple plot sets and walk away with this error message popping up on each one.
Thanks!
2 REPLIES 2
Did you ever find a solution to your problem? I am getting the same error messages but when I try to insert a additional query it erases my prvious query's
I was receiving the exact same errors. I never found the reason, but I did find a work around. I found that three of the five drawings I was querying were causing the problem. I went to those drawings and blocked all of the line work to a new drawing. Once I attached the new dwgs it worked fine. It not an answer, but it is a solution that got me through our printing
”Boost
